Jul 20th, 2024, 11:40am
dead-zones in delta-sigma modulators (first order) (Read 3016 times)
tul84
Sep 21st, 2015, 7:02am
can somebody give an explanation on dead-zones in delta-sigma
modulators. Can this effect be seen in simulation?
Re: dead-zones in delta-sigma modulators (first order)
Reply #1 - Sep 23rd, 2015, 9:23pm
There is a detailed discussion in "Understanding Delta-Sigma Data Converters" see Idle Tone Generation, page 42. The problem can
be seen in simulation.
saqibshah
Reply #2 - Oct 8th, 2015, 5:53am
Dead zones are a result of finite opamp gain gain in Sigma Delta Modulators. The reason that dead zones occur is because the opamp is not able to completely transfer the charge from the sampling capacitor to the integrating capacitor.
The effect of dead zones actuially results in a certain "minimum" input being present at the Modulator before it can generate a LSB so as to say. Roughly, a gain of 1/LSB(in volts) is necessary to avoid the Dead zone effect.
The post about recommends reading through the Temes book, which is an excellent source for understanding dead zones.
