Aug 15th, 2024, 10:47am
1/f noise in Cadence. (Read 2072 times)
saqibshah
Oct 08th, 2015, 5:43am
I am trying to simulate an integrator in Cadence, and look at the thermal noise of the opamp. However one of the problems is that CAdence usually takes 1/f noise into account as well while looking at the output noise.
Is there anyway to make Cadence ignore 1/f noise and just look at the thermal noise generated by the opamp?
Re: 1/f noise in Cadence.
Reply #1 - Nov 6th, 2015, 7:31am
If you have access to the model files, you could try to turn off the flicker noise in the model cards (kf=0 in some models).
