Jul 19th, 2024, 4:20am
mixed system simulation in cadence (Read 2928 times)
jovial
Oct 08th, 2015, 11:36am
hello all !!!
I want to simulate a circuit in "config" mode which has the following:
1) PMOS and NMOS from UMC_180nm library
2) a ideal comparator from ahdl library
3) a block whose functionality is written in verilog
4) an opamp using MOSs
When i am simulating it  using "ams" simulator , it is showing the following errors:
ncelab: *E,CUCFUN: instance 'M1' of the unit 'p_18_mm' is unresolved in 'new_afe_bunu.switch:schematic'.
ncelab: *E,CUCFUN: instance 'M0' of the unit 'n_18_mm' is unresolved in 'new_afe_bunu.not:schematic'.
ncelab: *E,CUCFUN: instance 'M1' of the unit 'p_18_mm' is unresolved in 'new_afe_bunu.not:schematic'.
ncelab: *E,CUCFUN: instance 'M0' of the unit 'n_18_mm' is unresolved in 'new_afe_bunu.switch:schematic'.
ncelab: *F,MAXERR: maximum error count reached (50).
ncelab: Memory Usage - 23.6M
Cn anyone help me how to run my simulation??????
AMS_ei
Re: mixed system simulation in cadence
Reply #1 - Jan 18th, 2017, 8:49am
You may not include the technology library files.
Thank you.
Kind regards
