jovial
hello all !!! I want to simulate a circuit in "config" mode which has the following: 1) PMOS and NMOS from UMC_180nm library 2) a ideal comparator from ahdl library 3) a block whose functionality is written in verilog 4) an opamp using MOSs
When i am simulating it using "ams" simulator , it is showing the following errors:
ncelab: *E,CUCFUN: instance 'M1' of the unit 'p_18_mm' is unresolved in 'new_afe_bunu.switch:schematic'. ncelab: *E,CUCFUN: instance 'M0' of the unit 'n_18_mm' is unresolved in 'new_afe_bunu.not:schematic'. ncelab: *E,CUCFUN: instance 'M1' of the unit 'p_18_mm' is unresolved in 'new_afe_bunu.not:schematic'. ncelab: *E,CUCFUN: instance 'M0' of the unit 'n_18_mm' is unresolved in 'new_afe_bunu.switch:schematic'. ncelab: *E,CUCFUN: instance 'M1' of the unit 'p_18_mm' is unresolved in 'new_afe_bunu.switch:schematic'. ncelab: *E,CUCFUN: instance 'M0' of the unit 'n_18_mm' is unresolved in 'new_afe_bunu.not:schematic'. ncelab: *E,CUCFUN: instance 'M1' of the unit 'p_18_mm' is unresolved in 'new_afe_bunu.not:schematic'. ncelab: *F,MAXERR: maximum error count reached (50). ncelab: Memory Usage - 23.6M
Cn anyone help me how to run my simulation??????
