Old Steve
NSW, Australia
Hi, this will be a little long-winded, but I'll keep it as brief as possible:-
I'm making a small Arduino-controlled robot car, and want to be able to make it home in on it's charger from a distance. Once close, I can use an ultrasonic sensor, then IR LED / sensor pair to get the car onto the charger 'ramp', but want to try to use the RSSI output from a 433MHz RF receiver to get into the general vicinity of the charger from further away, out of line-of-sight.
I'll use a 2kHz square-wave to modulate the transmitter carrier, so that it will be relatively easy to get a constant RSSI value at the receiver, independant of the actual data.
My plan, (so far), is to use a small DF loop attached to the receiver, but as I understand DF loops the car won't know if it's pointing directly towards or directly away from the transmitter.
My thought was to shield one side of the loop with a grounded tin shield, to provide a null area in that direction, so that the antenna is truly mono-directional. I don't know a lot about RF, so don't even know if this is a feasible idea.
Can anyone provide advice on this? It would be very much appreciated.
Edit: And if there's a better way to go about this, I'm all ears....
... Old Steve.
