Apr 25th, 2024, 11:47pm
Silvaco (Gateway, Expert, SmartSpice, SmartView ... ) - opinions (Read 3993 times)
Tako
Oct 22nd, 2015, 8:47am
My company thinks about using Silvaco software (Gateway, Expert, SmartSpice, SmartView etc.) for IC design. Has anyone have experience with this EDA tool? What do you think about it? What are your opinions?
Any advantages/disadvantages comparing to other EDA tools (Cadence, Synopsys, Mentor/Tanner...)?
Murat H. Eskiyerli
Ex Member
Re: Silvaco (Gateway, Expert, SmartSpice, SmartView ... ) - opinions
Reply #1 - Nov 4th, 2015, 3:10am
I would also be interested in hearing the opinions on this matter. A couple of years back we had some trial licenses, but unfortunately could not spend too much time. In general, tools look promising, but TCO was not significantly cheaper than the alternatives, such as Synopsys Custom Designer flow. On the other hand, I think there could be more available PDKs than the Mentor/Synopsys, but not Cadence.
  IP Logged
Tako
Reply #2 - Nov 4th, 2015, 4:20am
Hi Murat,
From the info I gathered, Silvaco has good opinions. Tools should be very intuitive, easy to use, easy to install and Silvaco has opinion to be good in  pulling PDK's from foundries.
You'll find some general info about CAD/EDA IC simulators here:
-> http://www.mtcmos.com/ic-simulators/ . Take a look also on Sources section.
and short info about Silvaco here:
-> http://www.mtcmos.com/silvaco/
There is also one more opinion from experienced designer, but it is on the other forum and I do not know if I can give a link to it here.
