Jul 21st, 2024, 1:31am
Common mode and diff mode exitation of current (Read 5885 times)
raja.cedt
Oct 24th, 2015, 8:32am
Dear All,
I have to excite a fully differential trans impedance amplifier (diff current to diff voltage converter), with 3mA fully diff current. Since I have learned diff and common components concept from voltage as input I tend to apply the same way (+1.5mA and -1.5mA on both sides) as shown in fig-2. But at the same time differential excitation means applying input between two input (for the time being please ignore how do we configure photo diodes like this) like fig-1. But circuit gains differ by 2 times.
With the simple differential pair concepts, I would guess fig-2 correct.
I would like to know whether people prefer fig-1 or fig-2, it's more what's the standard practice in the industry when they have to design diff TIA.
Thanks in advance.
Raj.
Re: Common mode and diff mode exitation of current
Reply #1 - Oct 25th, 2015, 4:25pm
Personall, I use a balun, in ADE the analogLib ideal_balun. The
inputs are the differential and common-mode signals. The outputs
are non-inverting and inverting. See the "The Designer's Guide
to SPICE & Spectre", page 115.
aaron_do
Reply #2 - Oct 25th, 2015, 5:44pm
In fig. 1 you have 3 mA flowing out of the top node and 3 mA flowing into the bottom node. In fig. 2 you have 1.5 mA flowing out of the top node and 1.5 mA flowing into the bottom node. i.e. its not a gain difference. Bottom line is you should configure your test bench to most accurately represent the real situation.
Aaron
raja.cedt
Reply #3 - Oct 26th, 2015, 2:48am
Hello all--
Thanks for the answers. What I am trying to say here is both circuits are different and hence all the parameters are diff(ex gain=2X), that's clear. Since I am new to diff current world and old to diff voltage, I am trying to use the same analogy for both voltage and current (I could be wrong). if some one ask me to excite an voltage amplifier with 3mV then I can apply
1. 3mV source between inverting and non-inverting terminals
2. +1.5mV at one side and -1.5mA on other side.
3.+3mV on one side and zero voltage (idea gnd) another side.
All of the above excitations will give exactly same voltage gain, so no need to ask the for the particular method, but looks like same method may not be applicable in case of current.
Hope this time I have explained correctly.
Raj.
aaron_do
Reply #4 - Oct 26th, 2015, 5:52pm
first of all,
I would say that this is not clear. The gain is still the same, only the excitation has changed. Anyway that's unimportant and you can continue using whichever definition you are most comfortable with.
See my attachment. IMO, the problem is the way you are splitting up the circuit. The differential amp naturally splits down the center to go from differential to single-ended in the voltage sense. For current, you would have to split it differently.
regards,
Aaron
raja.cedt
Reply #5 - Oct 27th, 2015, 1:39am
Dear Aron--
Thanks for the fig, I will think about it and will try to get where I am going wrong.
Regarding your comment--In my first post Fig-1 will have 6*Rf diff o/p voltage.Fig-2 will have 3*Rf diff o/p voltage.
Raj.
aaron_do
Reply #6 - Oct 28th, 2015, 5:34pm
Hi Raj.,
o/p voltage and gain are not the same thing.
regards,
Aaron
raja.cedt
Reply #7 - Nov 4th, 2015, 4:28am
Hello Aaron--
Yes you are correct. Finally I understood where i am doing wrong.
1. Fig-1 is correct, i mean if i have to excite with 3mA diff current, i should use +3mA and -3mA.
2.For a simple differential pair with Vin differential input, one transistor signal current is +0.5*gm*vin and another transistor carries -0.5*gm*vin, hence actual diff trans conductance (o/p diff current/input diff voltage) is 0.5*Gm.
Thanks for you help Aron,
Raj.
A Kumar R
India
Reply #8 - Nov 6th, 2015, 5:40am
Hi Raja,
One basic question about your last post.
You said diff. voltage of Vin..that means single-ended voltages would be...+Vin/2 & _Vin/2.
If you give these voltages to a normal diff. pair, it will produce io1 = +Vin/2*gm & io1 = -Vin/2*gm..
The output diff. current is io1-io2 = gm*Vin & the input diff. voltage is Vin.
So, the effective Gm is gm itself.
Where did you get 0.5*gm?
Bye
raja.cedt
Reply #9 - Nov 8th, 2015, 1:16pm
Dear Anil--
I didn't understand The output diff. current is io1-io2 = gm*Vin & the input diff. voltage is Vin.. Basically diff current is absolute value of (Io1,Io2) rather I01-I02. This is a very subtle concept, but it's not difficult to understand on your Won. Basically we have been spent years of analysing Diff voltage, so we all tend to use same convention by mistake.
Raj.
