Jul 21st, 2024, 3:28am
replace an ideal switch with transmission gate (Read 2006 times)
sara66
Nov 16th, 2015, 7:01pm
hi every one
I want to replace an ideal switch with transmission gate ,I want to know how can I replace ideal switch with transmission gate?
I just measure on resistance of transmission gate ,if this on resistance is equal to closed switch resistance,it means they are same?
Thank you so much
Re:  replace an ideal switch with transmission gate
Reply #1 - Nov 17th, 2015, 10:52am
depends on frequency and voltage range.
A transistor used as a switch has limitations of resistance, usable voltage range, and parasitic capacitance.
That's the simple answer.
DanielLam
Reply #2 - Nov 18th, 2015, 8:37am
1) For resistance: Sweep the input voltage range vs W/L to see if you can even meet the resistance requirement
2) For frequency: The transmission gate will add parasitic capacitance onto your nodes, so make sure the par. cap. is not significant at the W/L you choose
3) How much charge injection can you tolerate? This will depend on the clock edge steepness, input Vcm, device sizes, and load capacitance.
4) Decide on how to make clockbar. Can you use just an inverter? Or do you need to equalize delays -> related to charge injection in (3)
