Jul 17th, 2024, 5:15am
Wreal (Read 4116 times)
Adam_N
Wreal
Nov 25th, 2015, 8:43am
I'm new here and in Verilog-AMS modelling with data type wreal.
I propose to simulate a VHDL file with a few Verilog-AMS models (ADC, DAC and a plant transfer function) in irun environment.
1. Can the function @(cross(V(clk)-vth, +1)) be solved by irun
   simulator?
   If not, is there any simpler way to model behavior of a 10b ADC
   and DAC?
2. How looks like the Verilog_AMS model (with wreal data type) for a
   second order transfer function, sampled by Fs, like this
   H(s)=(s^2+ωz/Qz s +ωz^2)/(s^2+ωp/Qp s +ωp^2)
Thanks a lot in advance!
Cheers!
Adam_N
AMS_ei
Re: Wreal
Reply #1 - Jul 30th, 2016, 5:20am
wreal is a mixed signal variable. It is discrete in time and continuous in value. Hence, it uses digital solver to avoid convergence issues.
As it is uses event solver, hence it cannot be used in analog block. You have to use adsdelta () function to sample from analog value and then assign it to the wreal variable.
Hope this helps.
Thank you.
Re: Wreal
Reply #2 - Aug 2nd, 2016, 4:56am
For an example wreal dac, take a look at http://www.designers-guide.org/Books/dg-vams/ch4/ch4-listing09.tgz
