Aug 15th, 2024, 2:42am
Differential Quadrature Signal Generation of Low Power (Read 2123 times)
cheap_salary
Dec 10th, 2015, 9:41am
I would like to generate fully differential quadrature signals of 950MHz using PLL Frequency Synthesizer from 1900MHz differential VCO with low power.
Currently, I realize this by D-FF based on master-slave latch structure using CML.
However current consumptions are fairly large.
Alternate idea I have is using two D-FFs based on TSPC where one is rising edge triggered and the other is falling edge triggered. And I use two inveter and two buffer after them for generating fully differential quadrature signals, i, ib, q and qb.
However this scheme is pseudo differential.
Quadrature VCO can not be candidate.
I use 0.15um-CMOS of vdd=1.5V.
If you know good technique, could you share it with me ?
raja.cedt
Re: Differential Quadrature Signal Generation of Low Power
Reply #1 - Dec 10th, 2015, 12:48pm
use poly phase filters---
Reply #2 - Dec 14th, 2015, 10:06pm
agreed - poly phase or another reactive filter network structure
