Jul 18th, 2024, 2:34am
the problem of AMS code for capacitor (Read 1896 times)
eeBismarck
Dec 12th, 2015, 9:03am
Hi Guys,
   I am a beginner who is learning the verilogA by myself. Today I use the following code to model a capacitor
   `include "constants.vams"
   `include "disciplines.vams"
module sjw_cap(p, n);
 parameter real C = 0; // capacitance
 inout p,n;
 electrical p,n;
 analog
 I(p,n) <+ ddt(C*V(p,n));
when I run the transient simulation, and give the since wave as input. I find that the AC current is 0. Could you give me some clue ?
BR
Re: the problem of AMS code for capacitor
Reply #1 - Jan 5th, 2016, 6:29am
Did you specify a non-zero value for C in the netlist?  You could try setting the default to 1p to see if there's a problem passing the value from the instance line.
