raja.cedt
Left circuit: One typical application is Vth+(N*vdsat) generation commonly used in cascade bias circuits. N in this expression can be programmed by adjusting top device size(this device will be in triode region). For simple cascode bias, we need Vth+2vdsat, for that 1/3 of the bottom device would be suffices.
Right circuit: 1. This is nothing but a diode connected transistor with less vds---if you bias the top device properly 2. Source follower with improved o/p impedance due to -ve feedback if you apply input at the top deice gate
Refer Gray and Mayer book, you will find excellent explanation of these.
Best Regards, Raj.
