Jul 21st, 2024, 11:26pm
Voltage reference blocks (Read 1926 times)
baab
EA
Dec 15th, 2015, 6:26pm
Could anyone explain how these voltage reference blocks operate and how they are used in analog IC design?
raja.cedt
Re: Voltage reference blocks
Reply #1 - Dec 16th, 2015, 8:45am
Left circuit: One typical application is Vth+(N*vdsat) generation commonly used in cascade bias circuits. N in this expression can be programmed by adjusting top device size(this device will be in triode region). For simple cascode bias, we need Vth+2vdsat, for that 1/3 of the bottom device would be suffices.
Right circuit:  1. This is nothing but a diode connected transistor with less vds---if you bias the top device properly 2. Source follower with improved o/p impedance due to -ve feedback if you apply input at the top deice gate
Refer Gray and Mayer book, you will find excellent explanation of these.
Raj.
baab
EA
Reply #2 - Dec 17th, 2015, 12:49am
Thanks for the reply. I am trying to get a copy of the book. I will read it and ask you more after completing it.
