robotist
Hi my name is kim. I have a question about mismatch simulation. I just want to set resistor size by calculating standard deviation.
The attatched file describes my question and hand calculation I use propagation error formular with assumption that there is no correlation.
Surely, there are no parameter related correlation in model file.
The result in simulation is quiet different with my hand calculation. Maybe I missed something.
With same sheet resistor, how can I calculate resistor divider mismatch correctly?
Thank you for reading.
