ULPAnalog
Dear experts
I have the following question about feedforward compensated opamp. Referring to the attached figure, the usual implementation has Vb connected to the inverting input of Gm3. In such case, the output is only a function of Va-Vb and the loop gain is computed by injecting a current (shown in blue) and measuring the return ratio for unity feedback (shown in dashed line). Now, I consider the possibility of having the inverting terminal of Gm3 at incremental ground. Output voltage is now function of both Va-Vb and Va+Vb. My question is, does the process of computing return ratio by injecting the current still hold good and if yes, what does it convey, given the presence of both common mode and differential mode gains. If stability analysis were to be performed in spectre, does having iprobe in the feedback path ensure the correct evaluation of loop gain?
Thanks and regards
