Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 16
th
, 2024, 12:56pm
Home
Help
Search
Login
Register
PM to admin
Design
RF Design
› Second Order Passive Loop Filter for PLL
Previous topic
Next topic
Second Order Passive Loop Filter for PLL (Read 5295 times)
cheap_salary
Dec 20
th
, 2015, 8:23am
See attached figure, there are two structures as second order passive loop filter for charge pump base PLL.
How should I choose one of them ?
Just from component's value ?
IP Logged
Re: Second Order Passive Loop Filter for PLL
Reply #1 -
Dec 28
th
, 2015, 4:10pm
Preference (a)
Why?
It gives a single capacitor from the control voltage to the ground, which allows for the best HF filtering of switching noise.
The non ideal nature of the capacitor makes me go in that direction. Two devices in series will have greater parasitic inductance.
If everything is ideal, parasitics are ignored and non ideal charge pump switching is a non issue, then it does not matter.
However the reality is that they are all important.
IP Logged
nrk1
Reply #2 -
Dec 28
th
, 2015, 10:40pm
To have the zero well below the unity loop gain frequency, C2 >> C1 in your first circuit and C1 >> C2 in the second. The values will come out to be about the same. The first one is more common. There is always some capacitor at the output node and it can be absorbed into C1 in the first circuit. Also, it would be better to put C2 below the resistor or somehow ensure that there isn't a lot of parasitic capacitance from the junction of C2 and the resistor which degrades stability.
IP Logged
cheap_salary
Reply #3 -
Dec 29
th
, 2015, 7:22am
[Example]Kvco=22MHz/V, Icp=5mA, Ndiv=300, fc=10kHz, PM=45deg
T1=2.24e-7
T2=3.84e-5
T3=6.59e-6
Passive Filter-1
C1=0.0385uF
R2=207ohm
C2=0.186uF
C1+C2=0.2245uF
Passive Filter-2
C1=0.224uF
R2=142ohm
C2=0.0465uF
C1+C2=0.2705uF
Passive filter-2 requires large capacitor than Passive filter-1.
And we can not use grounded capacitor in passive filter-2.
So I don't think there is any merit to use passive filter-2.
Neverthless, these two structures are introduced in literature.
See following.
http://edadocs.software.keysight.com/display/ads2011/Open+and+Closed+Loop+Simula...
This ADS example use Passive Filter-1 now.
However Passive Filter-2 was used previously in same example.
See the followings.
http://edadocs.software.keysight.com/display/ads2009/Phase+Noise+Simulation
http://edadocs.software.keysight.com/display/ads2009/PLL+Simulation+of+DECT+Radi...
Here Passive Filter-2 is still used in these.
IP Logged
Reply #4 -
Dec 30
th
, 2015, 6:32pm
45 degrees phase margin?
Over process variance that may be a problem.
For a lowest phase margin corner I am good with it.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
»» RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
