Jul 18th, 2024, 2:20am
Problem of transition delay used in DTC verilog-A model (Read 439 times)
Hamlee
Tokyo
Dec 28th, 2015, 8:21pm
Dear all,
I am modeling a digital to time converter(DTC) using verilog-a code, and I met a negative delay problem. The spectre simulator always terminated when the DELAY move from a larger delay(say DELAY=100ps) to a small delay(say DELAY=20ps). Adding a fixed delay before DELAY will solve the problem, but I do not expect this fixed delay in my circuit design. Is there any better way to solve my problem?
Best regards,
`include "constants.vams"
`include "disciplines.vams"
module VERILOGA_DTC_11BIT(DIN, IN, OUT);
input [10:0] DIN;
input IN;
output OUT;
electrical [10:0] DIN;
electrical IN, OUT;
parameter tres = 300f;
parameter tr = 50p;
parameter tf = 50p;
parameter real Vhigh = 1;
parameter real Vlow = 0;
real DELAY, VIN, vout, Vtrans;
analog begin
	DELAY = (V(DIN[10])*1024+V(DIN[9])*512+V(DIN[8])*256+V(DIN[7])*128+
		 V(DIN[6])*64+V(DIN[5])*32+V(DIN[4])*16+V(DIN[3])*8+V(DIN[2])*4+
		 V(DIN[1])*2+V(DIN[0])*1)*tres;
	@(initial_step) begin
		vout = 0;
		Vtrans = (Vhigh+Vlow)/2;
	@(cross(V(IN)-Vtrans, +1)) begin
		vout = Vhigh;
	@(cross(V(IN)-Vtrans,-1)) begin
		vout = Vlow;
	V(OUT) <+ transition(vout, DELAY, tr, tf);
Re: Problem of transition delay used in DTC verilog-A model
Reply #1 - Dec 28th, 2015, 10:28pm
Spectre should not have any trouble with a decreasing delay. Perhaps you can show the results.
Hamlee
Tokyo
Reply #2 - Dec 29th, 2015, 8:59pm
Dear Kundert,
Thanks for your reply and suggestion. In simulation, if I keep increasing the delay (say DELAY = 10ps, 20ps, 30ps ....), it seems no problem at all. But if I decrease the delay (say DELAY = 320ps, 3ps), the error shows up. I attached the error message from spectreverilog simulator.
Reply #3 - Dec 30th, 2015, 10:54pm
It seems like a good error message. Have you tried bounding the delay so that it does not go negative?
Hamlee
Tokyo
Reply #4 - Jan 5th, 2016, 3:40am
Dear Kundert,
Thanks for your reminding. I finally realized my problem that I used an unbounded delay in transition statement. It will cause the delay go negative but the transition expression does not support the negative delay statement. I bounded the delay and it works!
Reply #5 - Jan 5th, 2016, 6:24am
How are you getting a negative value for DELAY?  Are some of the voltages dipping below zero (perhaps briefly due to capacitive coupling)?
Hamlee
Tokyo
Reply #6 - Jan 5th, 2016, 7:00am
There was no negative DELAY generated. The negative delay error in spectre shown in figure is owing to the unbounded DELAY in my verilog-a code. I added a fixed delay of 500ps to DELAY, then it works. I am not sue I understand your question precisely, plz ask me if you are not asking this.
Reply #7 - Jan 5th, 2016, 11:34am
Which is it?
For the first, I'd expect something like
 if (DELAY < 0) DELAY = 0;
 else if (DELAY > MAXDELAY) DELAY = MAXDELAY;
whereas the second would be just
 DELAY = DELAY + 500p;
In either case, what was the original value of DELAY computed from your formula?
If V(DIN[i]) is between 0 and 1, then wouldn't DELAY be between 0 and 2047*tres?  It doesn't seem like you'd need bounding -- unless V(DIN[i]) isn't between 0 and 1.
Reply #8 - Jan 5th, 2016, 10:47pm
It look like he is intending to convert the binary value of a bus to a delay value, but that is not what the following line does:
He is multiplying the voltage of each bit line by a power of two, but he should apply a threshold before multiplying by the power of two:
DELAY = (V(DIN[10] > Vth)*1024+V(DIN[9] > Vth)*512+V(DIN[8] > Vth)*256+V(DIN[7] > Vth)*128+
	V(DIN[6] > Vth)*64+V(DIN[5] > Vth)*32+V(DIN[4] > Vth)*16+V(DIN[3] > Vth)*8+V(DIN[2] > Vth)*4+
	V(DIN[1] > Vth)*2+V(DIN[0] > Vth)*1)*tres;
With his code, if V(DIN[10]) has overshoot and goes below zero, then the delay can go below zero.
Reply #9 - Jan 6th, 2016, 7:36am
That's what I was trying to get him to consider -- not just blindly bounding the result or adding a fixed extra delay, but understanding where the problem comes from.  That fixed extra delay might not be sufficient for other simulations.
Reply #10 - Jan 6th, 2016, 9:04am
Well it worked for me. I did not see the problem until your question.
Hamlee
Tokyo
Reply #11 - Jan 7th, 2016, 3:33pm
Dear  Geoffrey,
I think my last post is not correct. You are right, I added a 500ps delay to DALAY which make the error gone. But this is not the expected way the circuit should work. I corrected the code. Thanks for your question. It really made me think this question again.
		vout = Vhigh;
		vout = Vlow;
Reply #12 - Jan 14th, 2016, 5:20am
I think this is probably a significant improvement, only changing the value of DELAY when there's a crossing.  It's much less likely that the DIN voltages will have strange values at those few crossing times.
However, I think Ken's suggestion of using a threshold like (V(DIN[10] > vth) would still be a good idea, also.
