Jul 22nd, 2024, 9:32pm
PPV values from pss/pnoise simulation in spectreRF (Read 3539 times)
nrk1
Dec 28th, 2015, 10:54pm
I read an old presentation on "Noise aware PLL plugin" (https://www.cadence.com/rl/Resources/conference_papers/ctp_cdnlivesv2007_Thibier...). Apparently this has been discontinued. Anyway, in the presentation, it says that perturbation projection vector(PPV) values are stored in the simulation results directory(slide 17). Is this true of a regular pss/pnoise simulation in SpectreRF? If so, how would I make it save the PPVs and access the results? (SpectreRF certainly calculates all these, but I don't know how to access these)
nrk1
Re: PPV values from pss/pnoise simulation in spectreRF
Reply #1 - Jan 15th, 2016, 10:39am
Just in case someone else is interested in this. I discovered that there is an enable ppv option in pnoise which saves this data(accessible from results browser). Somehow I had overlooked this before.
ULPAnalog
Reply #2 - Jan 18th, 2016, 10:37am
Hello nrk1
Thank you for the information. Is this option also available from ADE-L pnoise analysis?
nrk1
Reply #3 - Jan 19th, 2016, 5:19pm
ADE  L  is what I used. (What is the alternative? )
ULPAnalog
Reply #4 - Jan 19th, 2016, 7:38pm
Setting ppv=yes in the spectre analysis statement for pnoise
