Was "net6" the original connection for MP2's drain, and "vddMP2" is the a new node you created between MP2 and the voltage source?
Is the voltage source inside the subcircuit? I assume you have changed the plot command to ask for the source's current, something like
.plot tran I(xX14.xX14.vddMP2)
But I'm not well-versed in Eldo.
