Jul 17th, 2024, 4:33am
Viewing device currents of transistor nodes (Read 488 times)
ksnf3000
Jan 04th, 2016, 8:45am
Hi All,
I have an eldo simulation going on. However I am unable to view the current flowing through the drain of one of my PMOS transistors.
The hierarchy is as follows:
.plot tran I(xX14.xX14.xMP2.d) is what I am looking for where MP2 is my PMOS transistor and I am looking at the drain current.
For this I added a 0V source
vddMP2 net6 vddMP2 dc 0 and then did the plot command but it still does not show me anything. Do I need to add this voltage source somewhere? Or please let me know an easy way to view device currents of individual transistors.
\ksnf3000
Re: Viewing device currents of transistor nodes
Reply #1 - Jan 5th, 2016, 11:39am
Was "net6" the original connection for MP2's drain, and "vddMP2" is the a new node you created between MP2 and the voltage source?
Is the voltage source inside the subcircuit?  I assume you have changed the plot command to ask for the source's current, something like
.plot tran I(xX14.xX14.vddMP2)
But I'm not well-versed in Eldo.
