Oct 30th, 2026, 7:59pm
What can we do with "subckts","instance", "model" and "output" results? (Read 4943 times)
Horror Vacui
Dresden, Germany
Feb 22nd, 2016, 9:37am
After a spectre simulation the results() command returns with results I do not know how could be used.
ocean> results()
(stb subckts instance stb_margin dcOp
    model output designParamVals "stb_reg-stb" primitives
    "stb_reg-margin.stb"
I do not know "subckts", "instance", "model", "output", "primitves" and "designParamVals". What data is stored in these simulation results and how could I use them? I have not found any reference in the  documentation Sad  but I am curious what tricks could be done with these. It would be enough to point me to the appropriate documentation. Thanks!
Re: What can we do with "subckts","instance", "model" and "output" results?
Reply #1 - Feb 22nd, 2016, 11:45am
Try "spectre -help info"
