Jul 23rd, 2024, 3:17pm
Virtual ground in switched capacitor integrator (Read 549 times)
jdp
Feb 27th, 2016, 4:39am
In a switched capacitor integrator (figure attached), it is said that the inverting input terminal of the op-amp is a virtual ground. How can we explain that? - because there is no resistor used in parallel to the feedback capacitor to ensure negative feedback!
-- jdp
raja.cedt
Re: Virtual ground in switched capacitor integrator
Reply #1 - Feb 27th, 2016, 8:33am
Interesting Question. During Phase-2, you have -ve feedback because of the capacitive potential divider. You need a resister in case if you have resister the opamp input like we do have in case of integrator.
Hope this helps,
Raj.
jdp
Reply #2 - Feb 27th, 2016, 7:31pm
Thanks Raja for your explanation !!
-- jdp
