Dec 15th, 2025, 9:53am
X Y snap spacing for layout window (Read 6446 times)
mixed_signal
Mar 07th, 2016, 9:03am
In display options form of Virtuoso layout window there are 2 entries X snap and Y snap. Which documents from foundry contain these information? Can anyone suggest me for TSMC 65nm?
ULPAnalog
Re: X Y snap spacing for layout window
Reply #1 - Mar 7th, 2016, 10:34am
Hello
This information is required to avoid off grid errors. Foundries can typically snap their mask dimensions to a certain scale. This will be part of the DRC rule manual and also you should find it in the rule deck.
ULPAnalog
Reply #2 - Mar 7th, 2016, 10:36am
Oh by the way, I think it is 5nm (0.005, when units are set to um in Virtuoso layout) for the process you have asked for.
Lala878
Reply #3 - Dec 6th, 2016, 11:47pm
You can always check it in your techfile by running a SKILL command in CIW:
techGetMfgGridResolution(techGetTechFile(geGetEditCellView()))
(basically what it does is call the techfile and render the info for you if I understood correctly myself)
it should output a value in um
