Jul 24th, 2024, 1:17am
Pages: 1 2
Can anyone give me more information on this amplifier structure? (Read 7684 times)
Littlepotato
Mar 10th, 2016, 11:18pm
I remember I saw this architecture once, but I forgot where it was.. Can anyone tell me what's this architecture for or where can I find more information on this architecture.
Thanks a lot
raja.cedt
Re: Can anyone give me more information on this amplifier structure?
Reply #1 - Mar 11th, 2016, 3:03am
Common Architecture for Ring oscillator--where you interpolate delay (from min to max) by varying the fast and slow path strengths.
refer razavi book, he explained clearly::)
Littlepotato
Reply #2 - Mar 11th, 2016, 8:57am
This actually is not an oscillator, it's an amplifier
Littlepotato
Reply #3 - Mar 11th, 2016, 8:57am
This actually is not an oscillator, it's an amplifier.......
raja.cedt wrote on Mar 11th, 2016, 3:03am:
ULPAnalog
Reply #4 - Mar 11th, 2016, 10:03am
Perhaps you are looking for a feedforward compensated opamp(?)
You may find some details about the same here
http://www.ee.iitm.ac.in/~nagendra/papers/tcas2-wlanfilter-pap.pdf
Littlepotato
Reply #5 - Mar 11th, 2016, 10:11am
what if I add another stage of amplifier at the output of the circuit?
Littlepotato
Reply #6 - Mar 11th, 2016, 10:11am
ULPAnalog wrote on Mar 11th, 2016, 10:03am:
Littlepotato
Reply #7 - Mar 11th, 2016, 10:12am
ULPAnalog
Reply #8 - Mar 11th, 2016, 1:55pm
It totally depends on what you intend to do. In general adding additional gain stages to an amplifier intended to be operated in feedback requires careful considerations about stability.
Reply #9 - Mar 11th, 2016, 11:30pm
that is a feedforward system
Littlepotato
Reply #10 - Mar 23rd, 2016, 11:22pm
can this system be stable?
Littlepotato
Reply #11 - Mar 23rd, 2016, 11:22pm
loose-electron wrote on Mar 11th, 2016, 11:30pm:
Can this system be stable?
buddypoor
Bremen, Germany
Reply #12 - Mar 24th, 2016, 3:00am
Littlepotato wrote on Mar 23rd, 2016, 11:22pm:
Why not? If there is no feedback, there will be no reason for instability.
ULPAnalog
Reply #13 - Mar 24th, 2016, 6:23pm
buddypoor wrote on Mar 24th, 2016, 3:00am:
Isn't this opamp going to be eventually used in some sort of feedback? If so why does the stability not matter?
RobG
Bozeman, MT
Reply #14 - Mar 27th, 2016, 3:14pm
As people have said, this looks like feedforward. Regarding stability, that is the purposes of the feedforward stage.
You have two OTAs in parallel. One uses multiple stages to provide high DC gain. Unfortunately the multiple stages will need to have limited bandwidth to achieve stability. Therefore  they put a high bandwidth single stage in parallel with it. Basically the multistage OTA acts like an open circuit at high frequency and all you have is the single stage.
I found another article from Thandri and Silva, JSSC, Feb 2003 http://amsc.tamu.edu/SIS/Publications/pub/jounal/2003_6.pdf
Feedforward is old but suffers from "doublets" which cause slow settling time. Achieving feedforward with parallel OTAs is relatively new and I don't know a lot about the drawbacks. Have any of you used this technique?
Pages: 1 2
