Jul 16th, 2024, 11:46am
Fractional spur in pll output spectrum (Read 2224 times)
shadow_cuk
shanghai
Mar 16th, 2016, 6:31pm
Dear all
 A fractional-N pll with its reference frequency of 10Mhz and divide ratio of 10.3 will get a output frequency of 103Mhz. It's known that the fractiional spur will occur at 0.3x10Mhz offset the center frequency, but in real test spurs at 1M/2M/4M also exist. Could any body explain that why there are so many harmonic frequency appeared?
raja.cedt
Re: Fractional spur in pll output spectrum
Reply #1 - Mar 17th, 2016, 1:03am
Think about coupling spurs!!! Refer the following!
A New Mechanism Producing Discrete Spurious Components in Fractional- N  Frequency Synthesizers
Best Wishes,
Raj!
shadow_cuk
shanghai
Reply #2 - Mar 17th, 2016, 6:19pm
Thank you raja, I've read the paper.  It mentioned in Fig.11 that a 105Mhz reference with a fractional divide ratio of 255/1024 could have
spurs at 410khz offset, with the author‘s equation I can't get a result of 410kHz,indeed 105M/410k is not a integer.
