Jul 24th, 2024, 11:23am
gm/id method (Read 2302 times)
JARVIS
gm/id method
Apr 09th, 2016, 11:11am
I'm using gm/id transistor sizing approach to design a low power opamp. I have a few questions regarding the same.
1) I biased the input transconductances in moderate inversion by choosing the gm/id of the differential transistors = 18, but while running dc simulation in cadence these transistors are shown to be biased in region 2 even though I get required gm. Is this correct? Will the transistors ever be in region 2 if they are in moderate inversion?
ULPAnalog
Re: gm/id method
Reply #1 - Apr 9th, 2016, 11:38am
Yes it is correct. It differentiates between strong inversion saturation and weak inversion saturation through region parameter being 2 and 3 respectively. For a gm/Id of 18 I would expect it to be on the verge of 2 and 3. You should see op region as 3 if you try to resize in such a way that gm/Id is around 22-25.
JARVIS
Re: gm/id method
Reply #2 - Apr 9th, 2016, 11:59am
okk thanks.
while sizing the transistors in the folded cascode, I used Vov = 2*id/gm and found the sizes from the gm/id lookup table. Since I used worst case condition currents, the dc simulation shows these transistors to be biased in region 2 but gm/id = 18 (since the current is less than worst case current) which implies that these transistors are close to subthreshold under normal bias conditions. Will this be a problem as these transistors should biased in strong inversion?
ULPAnalog
Re: gm/id method
Reply #3 - Apr 9th, 2016, 1:30pm
It depends on what your tolerances on specifications are. Or you could over design the transconductor stage so that it meets the specs even under worst case conditions.
