JARVIS
okk thanks. while sizing the transistors in the folded cascode, I used Vov = 2*id/gm and found the sizes from the gm/id lookup table. Since I used worst case condition currents, the dc simulation shows these transistors to be biased in region 2 but gm/id = 18 (since the current is less than worst case current) which implies that these transistors are close to subthreshold under normal bias conditions. Will this be a problem as these transistors should biased in strong inversion?
