Jul 18th, 2024, 8:29am
estimating 1/f corner frequency (Read 1065 times)
JARVIS
Apr 10th, 2016, 12:09am
I am trying to estimate 1/f corner frequency by doing noise analysis in cadence ADE L of a circuit designed in 180nm UMC Technology. Even though I don't get any errors, the input referred noise plot(output noise/gain)shows the 1/f corner to be in the order of MHz which is clearly too high since I'm not using any high-frequency transistors. What am I doing wrong?
ULPAnalog
Re: estimating 1/f corner frequency
Reply #1 - Apr 10th, 2016, 11:19am
Hello
It might be possible. Is the input device pmos or nmos? What are the dimensions and what the the bias current? Flicker noise corner depends on these factors.
JARVIS
Reply #2 - Apr 10th, 2016, 12:20pm
The circuit that I'm simulating is a basic Current feedback instrumentation amplifier .The input transconductances are biased in moderate inversion, and their sizes are around 50u/0.5u and tail bias currents are 28 uA. The circuit schematic is shown below
ULPAnalog
Reply #3 - Apr 10th, 2016, 1:46pm
Ok. A few more things to consider. Is most of the flicker noise coming from the input pair or from the current sources M41/42 and M71/72.
In general 180nm is a pretty much mature process and is generally well characterized and from my past experience with 180nm process (from other foundry though) is that the noise sims match pretty well with silicon data.
