Jul 18th, 2024, 4:14am
Plotting I-V curve in spice or verilog (Read 96 times)
gold
Mar 28th, 2016, 11:43pm
Hai,
I need to plot Id curve Vs Vg1 for various Vg2 values using verilog coding (or spice code).
Pls suggest me.
Re: Plotting I-V curve in spice or verilog
Reply #1 - Apr 4th, 2016, 8:40am
Verilog is a hardware description language, it's not a waveform viewer/plotter.
In Spice, one can set up simulations (and I think there's a way to define nested sweeps, but I forget the syntax in Spice 3f5, and it's a different syntax depending on exactly which Spice-like simulator you're using).  Do you have .alter in your simulator?
