Jul 19th, 2024, 4:23pm
Cosmos Scope takes very long to export an image (Read 2667 times)
AA
May 05th, 2016, 9:09am
Hi!
Exporting an image in Synopsys Cosmos Scope tool takes too long, even though it eventually works. By too long I mean about five to ten minutes.
Anyone has an idea how to make exporting images work faster in this nice tool, please?
Thank you.
Re: Cosmos Scope takes very long to export an image
Reply #1 - May 23rd, 2016, 5:41am
Do you have a lot of waveforms in your image, or a lot of points in a few waveforms?  I wonder if you have a lot of points, whether the export routine tries to plot every one of them, even if they're closer together than the resolution of the image you're trying to generate.
AA
Reply #2 - May 23rd, 2016, 4:13pm
Thanks for replying and the answer is no to both of your questions.
In fact, I figured out the problem. Exporting a non-postscript format while connected to the server through X11 session results in a very long conversion time.
The solution is to either choose EPS format or work on the server directly.
Exporting EPS is very fast even during remote X11 sessions.
Reply #3 - May 24th, 2016, 7:20am
Interesting!  Thanks for posting your solution.
