Jul 16th, 2024, 7:44am
Phase Shifter Design with a Branch Line Coupler (Read 1513 times)
nabla
May 22nd, 2016, 5:17pm
Hei,
i want to rebuild a 360 ° Phase Shifter from this paper "A Full-360 Reflection-Type Phase Shifter With Constant Insertion Loss for 2.45 GHz". If you canīt the the Paper on IEEEexplore here is the Link to the circuit of the Phase Shifter Design with a Branch Line Coupler.
https://goo.gl/93Hw0n
The Design:
I took the coupling factor rz = 2
I calculated the series inductor Ls with 2.354 nH and then the optimale Rp with 80 Ohm. The solution of ZB1 = 50 Ohm, ZB2 = 25 Ohm, Zt = 25 Ohm, Zt/2 = 12.5 Ohm and ZA = 25 Ohm.
I use the varactor diode from skyworks smv 1245
Afterwards I simulate the circuit in ADS. But my Problem is the structure of the circuit. Can you help me with the correct circuit. I simply do not achieve 360°  >:( What am I doing wrong  :-/ ??
« Last Edit: May 22nd, 2016, 11:31pm by nabla »
