Sep 1st, 2024, 1:16pm
Designing Discrete OpAmp (Read 4451 times)
soso
Jun 21st, 2016, 11:56pm
I am trying to analyse a discrete differential amplifier circuit by answering some question. I have done the analysis of the input stage, I would appreciate if I can get some feedback on my approach.
Kind regards
« Last Edit: Jun 22nd, 2016, 6:13am by soso »
soso
Re: Designing Discrete OpAmp
Reply #1 - Jun 22nd, 2016, 7:12am
Here is my analysis of the differential input stage
soso
Reply #2 - Jun 22nd, 2016, 7:16am
Here is the analysis of the PNP transistors in the input stage
soso
Reply #3 - Jun 22nd, 2016, 7:19am
Solution
soso
Reply #4 - Jun 22nd, 2016, 7:24am
Solution continues
soso
Reply #5 - Jun 22nd, 2016, 7:38am
Part three of solution
soso
Reply #6 - Jun 22nd, 2016, 7:54am
Part 4 of solution
Reply #7 - Jul 6th, 2016, 10:28pm
You need to look at 3 solutions - high common mode voltage, low C M V and middle range
they are 3 different things.
Also, why not just do a small signal model at the bias point?
