Aug 14th, 2024, 8:17am
Generate two high voltage levels in parallel (Read 2683 times)
bki
Jun 29th, 2016, 2:31am
i need to generate two voltage levels in parallel by using only 1 inductor: 40V and 20V
The idea was to generate 40V out of 5V (supply) with a boost converter and then bring the 40V down to 20V by use of an LDO...but the LDO has very bad Efficiency for this Operation (lage negative gain).
I have other ideas in mind like:
1. generating 20V with the boost converter and then use a switched capacitor circuit to double the voltage to 40V
2. harvest the energy anyhow from the LDO to not waste too much energy
Solutions with inductor like step-down converter is NOT an Option.
What do you think about it? What are your ideas for implementation?
Re: Generate two high voltage levels in parallel
Reply #1 - Jul 6th, 2016, 10:43pm
Create the 40V
Take the 40V and drive a switch at 50% duty cycle
Low pass filter
Output = 20V
Or:
Create the 20V
Take the 20V and use it to power a switched capacitor charge pump
Output = 40V
Neither method uses an inductor.
