Sep 1st, 2024, 11:31am
Remove the compensation cap, the opamp still stable? (Read 2330 times)
ludake
Jul 05th, 2016, 4:37pm
I built a regular 2-stage opamp with one compensation cap..... when i remove this cap, i see in the ac simulation that the phase margin is not enough, but in the transient simulation, i can't see the opamp is oscillating ?
 what't happening???
[ [img][/img]
buddypoor
Bremen, Germany
Re: Remove the compensation cap, the opamp still stable?
Reply #1 - Jul 6th, 2016, 12:52am
ludake wrote on Jul 5th, 2016, 4:37pm:
 what't happening???
[ [img][/img]
Oscillation will occur in case of a closed feedback loop only. Did you apply feedback during TRAN simulations?
Reply #2 - Jul 6th, 2016, 7:55pm
That is not an Op-amp, that is an OTA.
That said buddy is right about the feedback
