Jul 16th, 2024, 4:05am
AMS simulation error (Read 4232 times)
AMS_ei
Jul 13th, 2016, 6:13am
I am a new in this ams designer.
In my design there are two power domains. One is 1.8V supply (vdd) and the other one 1.24V regulator output (dvddao).
I have created the two sets of connect rules  CR_dynsup_full_fast_macau_dvdd and  CR_dynsup_full_fast_macau_vdd. These connect rules are using the connect modules from the cadence precompiled libraries.
I am successfully able to compile them and used in AMS simulation. After the elboration stage is complete, when Ultrasim is just about to start, it is showing me the following error:
ERROR: “esimPublisher/esimDbPublisher.cc” 7584 internal error
Here is the amscf.scs file that I've used in my simulation
In the amscf.scs file:
amsd{
        ie connrules=CR_dynsup_full_fast_macau_dvdd discipline=logic1v24 inst=“tb_top.dut.Icore_top.Idigital_top” net=“tb_top.chip_top_dvddao”
       ie connrules=CR_dynsup_full_fast_macau_vdd vddnet=“tb_top.dut.vdd” vssnet=“tb_top.dut.dvss” rout=0.001 vmax=3.6 discipline=logic1v8
Below are the irun options that I've passed in the simulation.
irun command lines options are:
   -amsconrules  CR_dynsup_full_fast_macau_dvdd -amsconnrules  CR_dynsup_full_fast_macau_vdd
irun version: INCISIV15.10.005
Could anyone please guide me how to resolve this issue?
Thank you.
Re: AMS simulation error
Reply #1 - Jul 13th, 2016, 10:58am
By definition internal errors are simulator errors not user errors. So you should definitely be talking to Cadence about this.
As a work around, you might try using the Spectre engine rather than the Ultrasim engine.
AMS_ei
Reply #2 - Jul 30th, 2016, 7:45am
Hi Ken,
I really appreciate your answer in this.
In actuality, I am running with full chip simulation. Spectre will take long time for simulation at the full chip level.
Is there any way that the simulation speed can be significantly improved without sacrificing its accuracy?
"reltol" may do that but it will sacrifice accuracy with improvement in speed. I am not sure of this.
Could you please explain me here how spectre could be used as a full chip simulator like Ultrasim?
Thank you
