Aug 25th, 2024, 11:22pm
Question on vco based ADC (Read 2025 times)
madhusmita
Aug 06th, 2016, 3:36am
Actually I am  working on VCO based ADC in 180nm technology . I have some doubts related to that topic.
1.I am not getting the correct output after DAC  when ramp and sine inputs are applied. so kindly let me know how u got the correct output
2. I have set the DAC (Vref=1,Vrise=0 ,Vfall=0,Vdelay=0,Vtran=.9)
3. I have set the  clk frequency  of  16.11 MHz .(vpulse period is 62ns and pulse width is 60ns) i.e reset signal to the counter
4. I  have used ramp signal of duration 3.4u
(when time=0s, v1=1v
when time=3.4us, v1=400mv.). ADC  count maximum when control volatge is .4vand minimum when voltage is 1v.
Kindly suggest the time duration of ramp so that i will get correct result.
madhusmita
Re: Question on vco based ADC
Reply #1 - Aug 8th, 2016, 2:16am
Kindly help Its urgent.Why I am getting this type of output. How to set the parameter of DAC in cadence for 6 bit ADC
« Last Edit: Aug 8th, 2016, 11:52pm by madhusmita »
