Aug 21st, 2024, 5:19am
hspice error for windows. (Read 2912 times)
tenso
USA
Aug 13th, 2016, 12:23am
I am running a 64 bit version of hspice and cosmos scope on windows 10. Cosmos seems to be working fine but hspice is quitting when I try to simulate. I get the message "hspice.exe has stopped working" and then just quits.
Any clue as to why this might be the case?
Re: hspice error for windows.
Reply #1 - Aug 22nd, 2016, 12:37pm
Generally, a problem like this would have to be reported to the vendor (Synopsys), but there are a few things you could try to rule out problems on your side.
Have you tried running a smaller/simpler circuit?  Eg, just a resistor and a voltage source in a dc sweep.
Can you run hspice in Windows 7 compatibility mode?
tenso
USA
Reply #2 - Aug 30th, 2016, 8:34pm
Thanks for the reply. I spoke to Synopsys and got it working. It was some license file issue.
