AMS_ei
I am trying to plot a digital signal using calculator after transient analysis. I am able to get the faithful result at individual output. However, while trying to calculate an expression (4 * VT("/oB<2>")), and simulate it, I am not getting the value 4. Instead I am getting 20V on Y-Axis, where oB<2> is declared as reg. I've run a transient analysis in ADE with AMS (spectre solver).
Please see the waveform attached.
Could anyone please explain me how can I plot a digital signal in an expression as mentioned above in order to obtain a value of 4 on the Y-axis and X-axis is time as is.
Thank you.
Warm regards,
