May 14th, 2024, 11:59pm
Issue with Expression plot in ADE calculator (Read 1442 times)
AMS_ei
Sep 01st, 2016, 12:48am
I am trying to plot a digital signal using calculator after transient analysis.
I am able to get the faithful result at individual output.
However, while trying to calculate an expression (4 * VT("/oB<2>")), and simulate it, I am not getting the value 4. Instead I am getting 20V on Y-Axis, where oB<2> is declared as reg.
I've run a transient analysis in ADE with AMS (spectre solver).
Please see the waveform attached.
Could anyone please explain me how can I plot a digital signal in an expression as mentioned above in order to obtain a value of 4 on the Y-axis and X-axis is time as is.
Thank you.
Warm regards,
AMS_ei
Re: Issue with Expression plot in ADE calculator
Reply #1 - Sep 1st, 2016, 2:44am
I have fixed it
