Jul 16th, 2024, 7:19pm
Do not use the `absdelay' analog operator in a conditionally-executed statement (Read 1380 times)
Rosh
Aug 29th, 2016, 11:32pm
I am trying to simulate the following code
	@(cross( V(utility)- V(ref),1))
		begin
                               V(tout)<+ absdelay(V(dut),10n);
However, the error states I cannot embed an "absdealy" statement in a conditional executed statement.
Is there any workaround for this?
Thank you,
Rosh
Re: Do not use the `absdelay' analog operator in a conditionally-executed statement
Reply #1 - Aug 30th, 2016, 11:08am
What are you trying to do??
What do you think happens on the "tout" terminal (port) when the cross event is not active?
What you've written, if any simulator were to try to implement it, would say that you want V(tout), at the instant that V(utility) - V(ref) crosses 0, to be a delayed sample of V(dut) from 10n earlier, and otherwise there is no contribution to the "tout" port.  That doesn't make any sense.
Rosh
Reply #2 - Aug 31st, 2016, 8:12pm
What exactly doesn't make sense here?
If utility crosses a reference voltage, V(tout) should be a delayed version of V(dut)?
How would I write such a statement then?
Geoffrey_Coram wrote on Aug 30th, 2016, 11:08am:
Reply #3 - Sep 2nd, 2016, 11:29am
What happens if utility doesn't cross the reference voltage?
Your cross statement only says what the model should do at the exact moment of crossing; you haven't said what happens for all the other timepoints of the simulation.
Reply #4 - Sep 2nd, 2016, 11:38am
I would think you want something more like this:
    real vout, vsamp;
    @(initial_step) begin
	  vout = 0;
    vsamp = absdelay(V(dut),10n);
    @(cross( V(utility)- V(ref),1)) begin
	  vout = vsamp;
    V(tout)<+ vout;
At the crossing, this captures a sample from 10n earlier, and holds this until the next crossing.  But I don't know if you wanted a hold, or if you wanted the output to be zero between crossings, or if you wanted the output to be zero until a crossing, and after the crossing to track (a delayed copy of) the input.
