Jul 22nd, 2024, 5:25am
Error in staircase expression plot in ADE (Read 3079 times)
AMS_ei
Sep 01st, 2016, 4:01am
Hi, I am trying to plot a staircase waveform from Calculator in ADE.
I have used the following function to generate the staircase waveform.
(((4 * VT("/oB<2>")) / 5 )+ ((2 * VT("/oB<1>")) / 5) + ((1 * VT("/oB<0>")) / 5))
as shown in the attached waveform. But, I am not getting the staircase waveform.
Could anyone please guide me here?
Thank you.
Warm regards,
Re: Error in staircase expression plot in ADE
Reply #1 - Sep 2nd, 2016, 11:26am
It looks like you're getting all the transition points right, but then the plot does a linear interpolation between them.
Can you just add up scaled copies of your net, without using the VT function?
AMS_ei
Reply #2 - Sep 2nd, 2016, 11:35pm
It is shouting with error. Hence, not able to plot waveform
AMS_ei
Reply #3 - Sep 3rd, 2016, 3:13am
It has been resolved.
Reply #4 - Sep 6th, 2016, 5:50am
Perhaps you could post the resolution for the benefit of later visitors to the forum.
