Jul 27th, 2024, 4:31am
Pages: 1 2
Phase margin in closed loop (Read 3453 times)
Re: Phase margin in closed loop
Reply #15 - Sep 06th, 2016, 7:20pm
Quote:
1) does my setup for measuring loop gain with iprobe look right to you?
Yes, as long as the two feedback resistors are part of the final circuit.
Quote:
2) I have seen a lot of people use the LC network setup with AC source above to measure loop gains of LDOs, bandgap references etc. Am I right in saying that you don't recommend it and stb is the right way to go about things?
Correct. And now you have seen an example of why it is not recommended.
tenso
USA
Reply #16 - Sep 6th, 2016, 7:24pm
Thanks a lot, Ken. I hope someone looking up stb analysis  benefits from this thread.
Pages: 1 2
