Jul 21st, 2024, 3:17pm
Transient Noise analysis in eldo (Read 1453 times)
ksnf3000
Sep 20th, 2016, 10:02am
I am doing a transient noise analysis using eldo. If I specify, the option for number of simulations=100 and check on no nominal simulation, it should run 1 noisy run. So is this noisy run including all the noise sources? And if I uncheck it, it runs for a long time giving a different output. What exactly is their difference? Was the 1 single noisy run equivalent to the 101 runs?
\ksnf3000
