May 6th, 2024, 1:01am
ngspice problems (Read 3589 times)
kiltanen
ngspice problems
Sep 30th, 2016, 1:04am
I'm running ngspice in batch mode and have following commands in my netlist
.AC LIN 10000 950e3 1300000
.PLOT AC VM(no6)
I get following error: Note: No ".plot", ".print", or ".fourier" lines; no simulations run
How can I fix this?
Re: ngspice problems
Reply #1 - Sep 30th, 2016, 11:25am
Could it be as simple as needing to have the .plot before the .ac?
kiltanen
Reply #2 - Oct 1st, 2016, 10:26am
I finally got got the simulation running after I fixed the issues with the netlist, but the simulation shows that ac magnitude in nodes no5 and no6 is zero. I'm attaching my netlist files in single package so someone might be able to say what is wrong with the model.  I use following command to run the simulation: ngspice -b -o rspice.log resonaattorit.cir
Holger
Reply #3 - Oct 5th, 2016, 8:54am
Node no4 has a DC source connected to ground. During AC simulation (small signal simulation) DC current sources are opened, DC voltage sources are short circuited.
Holger
kiltanen
Reply #4 - Oct 5th, 2016, 11:24am
the dc-source is used as bias voltage to linearize the transducers, is this possible ac analysis? how can i get the signal going though the subcircuit kytketyt_resonaattorit instead of the bias resistors? is there possibly something with the voltage controlled capacitance in NormalTransducer subcircuit? Also there is mistake in the netlist as the eta parameter of components Xs1-4 should be infinity not the same than in Xr1-4 components.
