Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 25
th
, 2024, 1:23pm
Home
Help
Search
Login
Register
PM to admin
Design
Mixed-Signal Design
› Op Amp gain required for Sigma-Delta ADC
Previous topic
Next topic
Op Amp gain required for Sigma-Delta ADC (Read 186 times)
ashrafSazid
Sep 30
th
, 2016, 2:33pm
I need help to determine the op amp gain required to match certain ADC specifications. I need to design a delta sigma 14 bit ADC and need to find out required op-amp gain. Is there any certain formula to find out that?
IP Logged
jdp
Re: Op Amp gain required for Sigma-Delta ADC
Reply #1 -
Oct 2
nd
, 2016, 7:11pm
If you search literature, you will frequently see that the opamp gain required is of the order of the OSR or more. Higher the better (like 60-75dB), but minimum is ~ OSR.
-- jdp
IP Logged
deba
Reply #2 -
Oct 15
th
, 2016, 12:01am
The loop gain required is of the order of (OSR/pi)^n, n is the order of the loop filter. But across corners, to have margin you need to design it for a higher loop gain.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
»» Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
