Jul 16th, 2024, 7:52am
RF limiter for sub 0dBm power (Read 815 times)
Hammad33
Oct 05th, 2016, 12:14am
Hello, I'm currently working on a receiver in which I would like to limit the RF power at input to -10dBm ~ -15dBm. All of the pin diode limiter (including schottky enhanced) schematics that I have seen limit power as low as 0dBm and not below that. I came across a limiter schematic given in Figure 16 of this link.
http://electronics.stackexchange.com/questions/74633/pin-diode-limiter
I was wondering if by using an amplifier before the schottky diode mentioned in Figure 16, can I tune the limit power to below 0dBm?
P.S, I would like to do it with as little active components as possible Smiley
Ancel
Re: RF limiter for sub 0dBm power
Reply #1 - Oct 7th, 2016, 12:01pm
Depending on the frequency band and permissible NF, have you considered a resistive  attenuator followed by an mmic amp. with a feedback control loop  as an ALC or manual level control.
Hammad33
Reply #2 - Oct 9th, 2016, 6:37am
@Ancel, thanks for your reply. I have considered a feedback loop using the detector that I'm using in my AGC but that would cause a delay of around 2 to 3 usecs, that I don't really want.
