Jul 21st, 2024, 9:21am
How to build amp's open loop gain simulation circumstance? (Read 2017 times)
bitplex
Oct 08th, 2016, 6:05am
Hi all.
A simple question from a freshling.
How to build an amp's open loop gain simulation circumstance?
for eg.
xi0 gnd inn inp out vdd amp
r1 inn out 1g
c1 inn gnd 1g
vinp inp 0 2.5 ac 1
It works, I don't know if there are another way to get this. Thank you.
buddypoor
Bremen, Germany
Re: How to build amp's open loop gain simulation circumstance?
Reply #1 - Oct 8th, 2016, 8:09am
bitplex wrote on Oct 8th, 2016, 6:05am:
r1 inn out 1g
c1 inn gnd 1g
vinp inp 0 2.5 ac 1
Can somebody translate, please?
Reply #2 - Oct 9th, 2016, 1:24pm
The approach you are taking, using a low pass filter to break the loop, is not accurate. You should use Spectre's STB analysis.
There has been plenty of discussion of loop gain analysis and stb analysis on this forum. Look around for more detail.
