Jul 16th, 2024, 10:02am
CMOS LC VCO phase noise sensitivity to pMOS/nMOS ratio (Read 3539 times)
deba
Nov 09th, 2016, 4:44am
Hi All,
For ring oscillators, it is known that by tuning the pMOS/nMOS ratio one can get a symmetric waveform. Resulting in minimizing the phase noise and 1/f^3.
1) Does the same phenomenon happen for CMOS LC VCOs?
2) And if it happens, is it applicable in both current and voltage limited regions of operation of VCO?
Horror Vacui
Dresden, Germany
Re: CMOS LC VCO phase noise sensitivity to pMOS/nMOS ratio
Reply #1 - Nov 30th, 2016, 11:02am
1) How does the waveform of an LC VCO looks like? This will answer your question.
2) What do you mean by current and voltage limiting? There is amplitude limiting usually due to a finite supply. I do not think in current and voltage limited regions.
deba
Reply #2 - Dec 7th, 2016, 5:02pm
Hi
Can you elaborate on the point "how does the waveform looks like"?
In current limited regime, the swings are proportional to the tail current. In voltage or supply limited regime, the max voltage swing is supply Vdd.
sarge
Belarus
Reply #3 - Dec 14th, 2016, 4:15pm
deba wrote on Dec 7th, 2016, 5:02pm:
Hi
I think the point here is that LC VCO has sinewave waveforms, and ring has CMOS.
Sorry for interrupting your conversation Smiley
Horror Vacui
Dresden, Germany
Reply #4 - Jan 9th, 2017, 2:13am
Exactly. A meaninful LC VCO has a high enough Q to suppress the higher order harmonics. So it is a fruitful approach to consider its waveform sinusoidal.
