Jul 16th, 2024, 4:44am
Output matching for cascode LNA (Read 5862 times)
engrvip
Nov 21st, 2016, 7:47am
I am designing a single stage source degenerated cascode LNA. I have understood most of it theory regarding input matching but dont understand how to do output matching of thi LNA ?
Hope someone can explain it to me.
Horror Vacui
Dresden, Germany
Re: Output matching for cascode LNA
Reply #1 - Nov 30th, 2016, 11:06am
With matching network? Any impedance can be transformed into any another by two reactive elements.
dog1
Reply #2 - Dec 1st, 2016, 4:20am
It seems to me that the degenerated LNA doesn't guarantee matching at the output in itself. If you want output impedance matching, then you have to use matching network at the output unless by coincidence your output is impedance matched.
engrvip
Reply #3 - Dec 13th, 2016, 8:06pm
Why is output matching not important between integration of on chip blocks in RFIC like between LNA and mixer ?
deba
Reply #4 - Dec 14th, 2016, 10:29am
Matching is more important for discrete RF design where one has to deal with external components.
In RFIC, matching is only important for blocks exposed to outside world. Like LNA and PA.
dog1
Reply #5 - Dec 21st, 2016, 2:24am
In order to answer this question we need to understand why we want to do impedance matching.
From what I heard and understand, there are two main reasons:
1. from transmission line point of view, the frequency response of transmission line and filter changes with the load (and the source) impedance. Also, when mismatch, there will be reflection and standing waves on the transmission line, which can cause problems (say, reflection into the free space through the antenna at the input of the receiver) and distributed V and I (deviation from standard circuit theory, thus making the circuit analysis invalid)
2. from circuit theory point of view, for maxim power transfer.
Note that the latter is based on circuit theory only and requires no distributed wave analysis.
when designing IC, say at the output of the LNA, if the mixer is place close to the LNA, the voltage and current in the interconnect is not much distributed over the line, and that the reflection in itself is not a problem. So reason 1 is not valid.
Additionally, reason 2 is valid only under the circumstance of drawing 1 in the picture attached, where you can have lossless matching network. However
1) on-chip inductor is lossy and costly.
2) in IC design we are very often interested in stable voltage and current, while by using matching network we are essentially creating an resonating network. Since in IC design, the load is very often purely capacitive, and the loss due to packaging and interconnect is small or non-exsiting, this often require large and almost purely inductive matching network. It is hard to build those inductors and the resonance gives large ringing on the line with pulsed input (long settling time and not suitable for digital and switching circuit). Say, in drawing (b), the input of the next stage is almost purely Cgs, thus the matching network will be almost just an L, and this LC network give a resonance and ringing.
DER19
Reply #6 - Oct 7th, 2017, 1:21am
although it is an old post but may help anyone.....we know that output matching is usually not important for LNA but for simulation and measurement of the standalone LNA, it needs to be terminated with 50 ohm. Therefore, draw your LNA and place a Common Drain buffer at its output. Adust its current such that its 1/gm = 50 ohms. This will give 50 ohm at the output of LNA. Now use a 50 ohm port easily for simulataions or a 50 ohm instrument at the output for measurement
Horror Vacui
Dresden, Germany
Reply #7 - Oct 22nd, 2017, 12:12pm
DER19 wrote on Oct 7th, 2017, 1:21am:
Do not say that in front of a professor or an RF engineer! The need for 50 Ohm mathcing has nothing to do with the circuit type, but the available gain, and the feasibility of a matching network. At 1kHz no one would consider an LC matching circuit, but it does not mean that it is not important in RF (I would say ~0.1-1GHz and beyond) circuits!
