May 6th, 2024, 6:03am
checking stability for a two stage fully differential simple OTA on cadence (Read 3134 times)
ahmedhany_94
Jan 05th, 2017, 8:26am
I made this circuit for a two stage fully differential OTA
I want to check its stability in a unity feedback but i have a version of cadence without the diffstbprobe
deba
Re: checking stability for a two stage fully differential simple OTA on cadence
Reply #1 - Jan 6th, 2017, 12:37am
You can apply a small step input and look for the number of rings or overshoot in your output. Or
you can break the loop using a large inductor and capacitor, if you want to look at the open loop gain in frequency domain. Take care of loading while breaking the loop.
Reply #2 - Jan 6th, 2017, 1:58am
If using an older version, you could use the older cmdmprobe component instead. This assumes that the two loops are balanced and that there's no significant CM to DM leakage (or vice versa), but is probably sufficient in this case.
Or you could use a more recent version. diffstbprobe has after all been there since IC614 (a hotfix of IC614 at least).
Frank Wiedmann
Munich, Germany
Reply #3 - Jan 10th, 2017, 12:31am
